If your car won't run, you can look for a ground pulse at the ignition coil while cranking. The TFI is what sends this pulse.
Otherwise, if the car starts to cut out at high RPM or when hot, some parts stores can bench test the module for you. Have them test it a few times to heat it up (to simulate the conditions in which it fails).
