TFS 1 vs B303
BYRDPE
1,556
Memphis,Tn.
I'm running the B cam with my present combo.
I have it advanced 4 degrees and it has good bottom end and really comes on at 3K- 5K.
I am curious to knoe how the TFS1 would change my engine charactistics.
Anyone tried both in the same combo?
What rpm range does the TFS make power?
Thanks
My TFS1 has pretty much no bottom end, but you have an intake that will promote low end torque, so you should be in better shape than me. I'd think with it advanced 4° like you have the B cam, you'd make some pretty decent power. FWIW, my stage 1 cam pulls all the way to redline, and feels like it's got a good amount left to go. It doesn't make any power until after 3K though.
Ok...thanks for the info.
Judging from your post if I was to run the TFS1 looks like I'd advance it also. I kinda like the lowend grunt on the streets.
So in essence the TFS1 would be almost the same as the B.
I feel that the TFS cam would actually work well in your case the TFS1 cam was designed by TFS to work with their heads that have some of the best low lift numbers in the biz. Your Thumpers are kind of ported for the same purpose to help the low lift so I think I would give it the nod and and up the rears to 4.10's. It amazes me the number of people that run this cam with stock heads that have about the worst low lift numbers on earth is it just because of the lift specs people run this camshaft on stockers?
Thanks for the reply.
So 4.10 to help the low and retain the top end the TFS1 provides.
Just curious to what you mean by this. :shrug:
Would these ppl see any gains or does it hurt performance with stock heads?
the ramps and profile of that camshaft was designed to accentuate the high flow at low lift design of TFS heads dont get me wrong the camshaft will work in a stocker 302 but you would not get the full effect of the camshafts intentions.
I can't guarantee that my loss of low end isn't related to my intake choice as well. I'm running the Typhoon, which is a copy of the original Edelbrock Performer RPM. Don't get me wrong, my car will blaze the tires if I side step the clutch, but in my application, the low end just isn't there to me.
