Update on the situation..
Since my fmu is calibrated for 19 pound injectors, i figured it was getting too much fuel... i disconnected the vac line off the FMU to see if it made a difference since 24 pound injectors should be enough without the FMU... the same problem is there... i can take the car about an inch off the floor to about 3 pounds of boost to redline and its fine... the second i hit the floor , at 4500-4800ish, i will get a NASTY fall on its face.... im beginning to think its not a fuel problem, but i can be wrong.... can i try to turn the check valve the other way to see if it makes a difference?? im running out of ideas..im clueless
