P ponsai03 New Member May 24, 2009 21 0 0 Sep 8, 2009 #1 Sep 8, 2009 #1 Can someone tell me if I can use my factory 5.0 Mustang pushrods with GT40 heads and TFS1 cam? I will also be using stock GT40 rockers and Trick Flow spring kit. Thanks.
the pony boy Founding Member Apr 19, 2002 358 0 16 10512 Sep 8, 2009 #2 Sep 8, 2009 #2 yes.i have the same setup with 1.6rr.many have used the stock pushrods.
lancec2c30 Member May 14, 2008 570 0 16 Washington Sep 8, 2009 #3 Sep 8, 2009 #3 You could do it, but it really would be best to measure out the correct length pushrod you need.
LarsD Founding Member Jul 2, 2002 2,680 119 123 Texas Sep 8, 2009 #4 Sep 8, 2009 #4 I ran stock pushrods with my old 306, you really should measure though.
lincoln+ford Member Jul 4, 2009 195 0 16 Sep 8, 2009 #5 Sep 8, 2009 #5 I used my stock pushrods.But my heads have never been cut neither has my block.
P ponsai03 New Member May 24, 2009 21 0 0 Sep 9, 2009 #6 Sep 9, 2009 #6 Thank you guys for your help.
