myslo50 Member Jun 12, 2006 247 3 18 ohio Mar 15, 2009 #1 Mar 15, 2009 #1 i need to know if someone has the cam card for the tfs1 cam, and if you could scan it. i need to know the cam timing and some other info off the card. i found mine 2 weeks ago and cant find it anywhere.
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,265 17,952 224 Massachusetts Mar 16, 2009 #2 Mar 16, 2009 #2 bump. I'd like this info as well
66sprint6 Member Oct 5, 2005 131 1 17 Mar 16, 2009 #3 Mar 16, 2009 #3 Well...crap, i know I got it somewhere but Im at work. Ill see if i can find it tonight. Hopefully someone will chime in before then for you tho. Matt
L LxVert Member Dec 26, 2003 80 0 6 Mar 16, 2009 #4 Mar 16, 2009 #4 I dont have a scanner but here is all the info from the card. TFS-51402000 Valve Setting: Intake .000 Exhaust .000 -------> HOT Intake @ CAM 312 @ VALVE 499 ROCKER ARM RATIO Exhaust @ CAM 319 @ VALVE 510 1.6 CAM Timing Opens Closes Advertised Duration @.006 Intake --- -- 275.0 degrees Tappet Lift Exhaust --- --- 279.0 degrees Cam Timing OPENS CLOSES MAX LIFT DURATION @.050 Intake 3.0 degrees BTDC 38.0 degrees ABDC 108.0 degrees ATDC 221.0 deg Tappet Lift Exhaust 49.0 deg BBDC (4.0) deg BTDC 116.0 deg BTDC 225.0 deg
