Got the new alt wired in as WORTH advised a few days ago ( http://forums.stangnet.com/showthread.php?t=489444 ), and since then have been working on various other parts of the car after testing that everything started up well (let me be the first to tell you what a difference re-grounding and re-wiring all your engine compartment electical harnesses can make... she runs so much better now).
BUT now I believe that my battery is not charging. The car is fine when running but the charge disappears quite quickly otherwise, which leads me to believe that the only charge that it's been keeping is what is jumped into it from the other car.
I've been told and seen on here that that is likely because in the process of redoing all this that I fried my voltage regulator. I've also been told that I need to make sure everything is wired correctly now, so that I don't fry the next one I put in too. So I need to figure out how to do that. Any ideas?
Must have been because of the points and a stock coil. My 68 Merc was havin charging problems the other day, we pulled the pos term. off and it immediately died. It's got a pertronix unit and flamethrower coil, nothing else in the car was on at the time.
