ARP makes a great product. I think everyone knows that by now. The thing is, they make head studs with these so called "optional features". I'm wondering if these extras are worth it for me.
12-point nuts
ARP says that a 12-point nut will allow you to retorque the head without removing the valve train. Is this even neccessary on a small block Ford ? Is this something that depends more on the valve springs you use then the type of head ? I'm just wondering if this will really save me any time at all.
undercut studs
From what I've read, the way I understand it is that an undercut stud has a small amount of metal removed from the stud in the area between the threads so that the studs are slightly more flexable. This supposedly helps to maintain the preload on the nut should lose some compression.
I did a search on google and read in another forum that the undercut studs are weaker. This guy called ARP and the tech told him undercut studs are better for street use and regular studs are better for race only engines.
I can't see a properly installed head gasket going south when used with studs and the head being correctly torqued. Are undercut studs worth the extra cash ?
12-point nuts
undercut studs
