THE FRIGGIN FUMES ARE KILLIN ME!!!
would it do me any good to put cats back on my car without the emissions crap under the hood? the fumes inside are killin me, i know i dont have any exhaust leaks, and i figured once i put a full exhaust on it would blow out the back, and not really bother me, but it does, will it help to put cats on, or do i have to have it all to kill the fumes? :bang:
when ever you remove cats, you get a distinctive smell that can be real bad. I would try putting on your stock h pipe just to see if it gets rid of that smell for you. I know what you're talking about, and it's not fun.
Catalytic converters without the smog pump will fail sooner than they would with the smog pump. The extra air helps burn up the hydrocarbons and keeps the cats for carboning up and being coated with sludge.
For fun, try those fluids that scent the exhaust...they have bubble gum, blueberry, etc. Seriously, I would try and find out where the smell is coming from. If you smell it all the time, you may have an interior exhaust leak, and while the smell may be bad, the CO will kill you. With the cats on you may not smell the unburnt gas, but the CO is odorless, and may still be leaking into the car. My 2 cents.
bassaini = expensive. Catco = cheap. best bet if you want to do it on the cheap, pick up a pair of catco hi-flo cats, go to a shop that welds, mieneke - speedy - midas and ask them if they will weld on the cats. Some wont touch it others will if you slip them a $20. Better even if you already know of someone who will weld them on
