So when I hit larger bumps and dips in the road or drive through corners with speed my car will cut out and recover again.
It seems like an ignition thing because the RPM will drop to zero then recover. It'll happen quick when it's a bump or dip but if it's a long corner that I'm pushing through it will cut out and come back sveral times...
Can someone explain where the inertia switch is in the trunk so I can start with the easy fix?
thanks
thanks
