The saga continues starting problem solved now runs like crapola
Thanks to all who have helped me with my starting problem. :SNSign:
And special thanks to HISSIN50.
The problem was one of the ground wires. I replaced all the battery posts and the neg cables and it started kind of.
Now the car will not run.
It starts but it's like it's flooding out and you have to keep it at almost full throttle to get it to run. It coughs and smokes and smells like fuel.
<o></o>
The car has sat for almost 2 months with the starting problem and the battery has been disconnected so many times. Did the computer lose its memory?
It will start but runs like crap and will not stay running without almost full throttle, smokes and misses.
I have tried to run my code scanner but it will not even pick up codes or run the scan complete.
<o></o>
Before my car first had its starting problem it was running perfect and I had no problems. All I did was drive home turn the car off and 1 hour later went to leave and nothing. Would not start! Replaced the starter, starter relay and all the cables and it starts but runs like crap.
What now?
<!--[endif]-->
<o></o>
<o></o>
What now?
<!--[endif]-->
