The SN65 project car
Actually, I'm thinking that there should be no graphics or trim at all and even go as far as shaving the door handles and smoothing other features. This car will look absolutely amazing the cleaner it is.
I agree with the chrome bumpers instead of painted to match, but really like the idea of shaving the bumper bolt heads and having the bumpers rechromed. Even if you're buying new repop bumpers, the chrome isn't that great anyway. Toughest thing would be installing it after smoothing them. Maybe the thing would be to alter the bumper brackets and instead of welding the bolts to the bumper and shaving the heads, you could fill the square holes and weld nuts to the underside of the bumper. Then shorter bolts and lockwashers would be used from the backside (if possible).
Ok, ya'll want to see ideas, well here! -This should just about settle everything that has been said above :flag: And if you want to see anything else let me know I'll see what I can come up with!
Talk to ya later, Cory
definitely looks kinda plain without something on the side. i also think that if you go to the trouble of shaving the bumper bolts you should also narrow them as well so they tuck up tighter to the body.
here is a thread on the VMF where another stanger did a custom grille with some really cool looking GT style foglights but with no grilles bars or corral
http://forums.vintage-mustang.com/f...23&Words=grote&topic=&Search=true#Post1212930
SNIP...
Hi Cory,
Excellent job. It really helps to be able to see some of these things in more than my minds eye.
I am going to let these things sink in a bit before commenting on any one image.
Thanks for all the hard work.
SN65 said:
Hi Cory,
Bob,
No problem! They are a little sloppy, but i thought it would atleast give you an idea of something to look at. If you want to see anymore ideas or even a 100% better photochop job just let me know!
Cory
Hi All,
Yesterday, I worked on the final engine plumbing details. Radiator and air intake. Everything went pretty well. Not perfect, just pretty well. :-)
To complete the air intake I need to locate one sensor and plumb up one vacuum line.
My biggest problem is the lower radiator lines. I have posted some photos (more available at the website) showing the incredibly tight spaghetti bowl of lines and hoses in this area. Everything is pretty good, but I only have about 1/8" clearance between the sway bar and the hose / thermostat housing. There is plenty of flex in the plumbing (if the sway bar pushed on the hose, there is about 1 1/2" of movement). My problem is that there is nothing to tie the hose / housing to save the power steering rack and doing this is a bit problematic. I am thinking that I can make a bracket that ties the bolt of the housing to the rack, but there is nowhere on the rack to bolt to. I am going to have to kick this around for a while until something comes to mind. In the mean time, I am going to place a rubber "shield" around the sway bar to keep it from chaffing the radiator hose.
Any recommendations would be appreciated.
Catch ya'll l8r
Bob, can you make a bracket to attach to the two holes on the yellow bracket in the middle picture? It'd have to clear the three vacuum lines, but maybe you could get one of those plastic clips that the snap into and mount it to that bracket as well. Paint the bracket semigloss black like the bracket to the left of it in that picture that's under the shroud and use CAD plated fasteners and I think it might look factory.
