ok to start off here is what the stang has:
flo tech headers
bassani o/r x pipe
flo master 2 chamber cat back
under drive pullies
cam ( i think the e303)?
mac cold air in the inner fender
adj. fuel pressure reg.
ford lowering springs
3.55 gears
steeda lower rear arms
steeda adj.upper rear arms
nitto d/r's
pro 5.0 shifter
sreeda cable quadrant and fire wall adj.
spec stage 1 clutch
now for the question i run low 14's basically 14.0's 14.1,2,3's but i see guy's running faster times then mine with almost less thing's done so WTF? my 60' is like 2.0/2.1's my 1/4 mile is 94-98 mph with the 1/8 in like 76 mph or so. my fastest 1/4 mile time ever is 13.998
most of these times is without the d/r's or the rear upper's and lower's i have ran with the d/r's and the upper's and lower's but still the same,but i do releize that i need to adjust the uppers from the stock setting tho. so bascially anyone got some pointers or are these good/decent times for the stuff done to my 95 gt? any and all help would be great. peace
john
flo tech headers
bassani o/r x pipe
under drive pullies
3.55 gears
nitto d/r's
pro 5.0 shifter
spec stage 1 clutch
most of these times is without the d/r's or the rear upper's and lower's i have ran with the d/r's and the upper's and lower's but still the same,but i do releize that i need to adjust the uppers from the stock setting tho. so bascially anyone got some pointers or are these good/decent times for the stuff done to my 95 gt? any and all help would be great. peacejohn
