84convertablegt said:...if you are a good driver, you constantly scan the road, your mirrors, you gauges. you dont notice you are doing it, but u are subconciously always checking these things. if you own a classic car, you should always be checking all your gauges.
wow. apparently i am a bad driver. I dont care how often you check your gauges. in less than 3 minutes my oil pump died and my engine blew. If you can honestly tell everyone that you have never in your life driven longer than 2 minutes without checking your oil gauge. then i tip my hat to you.
Fact is i did then, and still now check my gauges regularly. but when you have a 3 minute or less window for complete melt down, the chance for you to notice the oil gauge in time to save your engine is pretty slim, at least in my case. as for changing your distributor and droping your oil pump drive shaft in the pan. well, i can see how the gauge would be usefull there.
in cases of over heats, you have tell tale signs usually to help you notice the problem, steam, coolant smells, and enough time usually to notice your rising gauge or temp light before you start damaging things.
Volt gauge too gives you a fair amount of time to notice it before your car dies as it will run for some time on the battery without an alternator that works.
But with no oil or oil preasure, your car will often run like a dream...right until it grenades.
I have driven in Columbus and youngstown Ohio, and i can tell you the roads there are far safer and calmer than san diego CA. you may have more opportunity and few distractions for more frequent gauge checks, and may have noticed the oil pump failure i had, when i myself missed it. I doubt it though.
I believe in regular gauge checks...
However, i still think that given the window of opportunity to notice a dead oil pump. or the fact that the gauge will show you fantastic oil preasure even when you are almost completely out of oil, i still rate this as one of the least important gauges
