thermostat temperature
  • Thread starter Thread starter 67matang
  • Start date Start date Feb 20, 2004
67matang
38
rose creek mn
Feb 20, 2004
  • Feb 20, 2004
my car's temp usually is 210 but when im in town sometimes it will go over that. the thermostat temp in it right now is 195. would it help if i got a 180 degree thermostat?
thanks
12sec67
1,301
San Diego, Ca
Feb 20, 2004
  • Feb 20, 2004
with aluminum heads your car will run better at a lower temp.
with a 160 thermo in mine, it never goes higher than 175.
you have a little more colder weather than i do so a 180 should work well for you durring the winter and durring the summer try a 160.
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Feb 20, 2004
  • Feb 20, 2004
You could try it, but based on the assumption that your gauge is correct (is it?), I would look into other problems in the cooling system. Things to consider are:
1. Are you running more than a 50/50 mix of antifreeze and water? Anti-freeze is not efficient at removing heat from the engine, its purpose is to prevent coolant freeze-up and to inhibit rust.
2. How's the radiator? Is it large enough for your application and in good condition?
3. How are your belts and hoses? Belts can get old and slip on the fan/watr pump, and hoses can rot from the inside out and impede coolant flow.
4. What about the water pump? The vanes can wear/rust down over time.
5. Where is your ignition timing set? That can cause excessive engine heat too.
6. Is your carburetor jetted too lean?
I am sure there are several other items that you can think of that are worth looking into also.
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
D
1996 gt mustang block temp vs coolant temp
  • Dkuehn
  • May 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 22, 2026
squeak93
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
