  • SN95 4.6L Mustang Tech
Thermostat...
  • Thread starter Thread starter HellBoundMB
  • Start date Start date May 16, 2005
H
HellBoundMB
9
  • May 16, 2005
Any of you guys know what the stock thermostat on an 01 GT is? I was wandering through Pep Boys today while buying some cleaning ****, and I came accross thermostats and thought maybe I could put a lower temp one in and it would help keep the engine a little cooler? I dunno, I'm not a real car guy yet, but I hope to get there one day. Does this work, does it run any danger to the engine?
Barrier
155
  • May 16, 2005
Thermostat = the valve that lets coolant flow when the engine reaches a certain temp... its the metal part that connects to your upper radiator hose right beside the alternator... dont think 2 would make much of a difference, itd still open at the same temp.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 16, 2005
  • May 16, 2005
a lower one will make the motor run cooler. the stock one is a 192degree one i believe, maybe 195. generally people put in a 180 t-stat.
Barrier
155
  • May 16, 2005
Oh really? Wouldnt it be easier to just replace the thermostat?
triggz
1,218
Gadsden, AL
May 17, 2005
  • May 17, 2005
Its common practice to replace the thermostat with a 180* one. I have it in mine. You should tune the ecu for the fan to come on at the lower temp as well though.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 17, 2005
  • May 17, 2005
? i just read everybodys post too this a few times and i don't see where you think they are not talking about replacing it.
go with a 180 your car will run a little cooler.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 17, 2005
  • May 17, 2005
....but no lower than a 180. Running a 160 in a fuel injected car = bad news for power, smog and fuel economy.
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
