a few years ago i rebuilt a 289 for my falcon put about 3000 miles on it then traded it out for 302 efi. that was a little over a year ago. then about a week ago i bought a set of afr 165's for it and popped it in my capri. when i had the heads off the bores looked just like they fresh out of the machine shop less the carbon at the top. along with it i installed a isky 280 mega cam and a new tci c4(replaced worn out e303 cammed 302 w/t5, ported 289 heads). on first start up it knocked at idle for awhile, it sounded like flywheel to bell plate hitting. so i shut it down and bent the plate away a little. the noise mostly went away. took it for a short drive, and returned to check the rocker arms(some valve noise). all adjusments were good, contact patch on valve tip centered. so i cranked it for awhile while watching and listening and #1 intake clickes when it closes?!?!?. the retainer dosnt hit the rocker, pushrod dosnt' hit the head wtf. so i cranked it some more then noticed the oil looked sorta metallic, thought new cam and lifters probably initial wear. curiosity got me and i put a magnet in a rubber glove , it's not magnetic. (insert choice words here) i think i took out a main on a low milage motor i changed the oil right before startup and even primed the system. any other things you guys can think of, im lost other than bearings, and that shouldnt of happened.
