Think this'll need bigger injectors?
Josh97GT
101
I am almost done on a large mod that involves an entire PI swap and stage 2 PORTED PI heads. A few other things as well. I'm estimating to be around 300+rwhp in the end. Not to mention the compression in Pi swapped Sn95's is larger than the 99+ Gts, so even if this makes me faster, I think I would need bigger injectors correct? Currently I pur the ones that the 00 models came with on, I believe they are 19lb
I have 19 lb injectors on a 11.1 compression built motor with pi heads and intake on a 96gt. 24's are ideal and you could upgrade to 30's but its not necessary. Best thing to do is ask your tuner what they think you should go with since they will be tuning your car.
