  • 1994 - 1995 Specific Tech
This does not look good
  • Thread starter Thread starter pwcracer
  • Start date Start date Apr 14, 2007
pwcracer
347
Hastings, MN, USA
Apr 14, 2007
  • Apr 14, 2007
I installed my rebuilt SC a few weeks ago, and drove it only a few miles. Tonight it was finally warm enough to really test it, and everything seemed fine. It had lots of power, and I never heard any detonation. I was even able to spin the tires in 3rd gear!
I parked it and when I went back out, i noticed it dumped about a gal, of coolent on the ground.. I can only assume this might be the tell tale signs of a head gasket failure *Again, this would be second time...
What do you guys think.. That to me is the only reasonable explanation.. Why else would there be so much pressure in the radiator to push out a gal of coolent out the over flow.. My car is F'ed isn't it???
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 14, 2007
  • Apr 14, 2007
Before you panic, make sure to top if off completely and get all of the air out of the system. Air pockets in the system can cause a ton of headaches such as this one in particular. I can't tell ya how many times I've seen cars puke out coolant, only to have it be a level or thermostat related issue, when the coolant just got too hot and expanded to the point of overfilling the overflow tank and dumping it on the ground. Just make sure your system is up to par first. A new thermostat and cap shouldn't be more than $10, and before you tear into the engine, it could save you some very large headaches, and your hair, before you pull it out by the handful.
MI95Cobra
451
Oklahoma City
Apr 14, 2007
  • Apr 14, 2007
yeah i would check the cap...it says after every flush...change it....
parchisi
519
New Mexico
Apr 14, 2007
  • Apr 14, 2007
EEK!! That's why I'm getting my tune asap before I even think about hammering the throttle! I hope its something simple, good luck.
FlyBy763
439
Palm Bay, FL
Apr 14, 2007
  • Apr 14, 2007
Mine was overflowing the last time I was at the track. It was just a hot day and me running my car caused the coolant to rise high enough to where it would overflow because I filled it too high the last time. Check the simple stuff first.
J
jabGT
59
Michigan
Apr 15, 2007
  • Apr 15, 2007
most likely head gasket if it is spewing that much coolant, its easy to tell. had it happen a few times.
m0l0
178
Apr 15, 2007
  • Apr 15, 2007
Also a compression/leakdown test will tell you more before you start wrenching
Hope is nothing hard
Pokageek
2,767
MA, USA
Apr 15, 2007
  • Apr 15, 2007
Same thing happened to me days after installing my turbo on my old car. The HG must have been a little weak to begin with and my turbo or (your s/c) possible just helped it to its demise more quickly.
On my car, I was driving down the road and dam if the hot coolant wasn't spewing out on my feet!!! :damnit:
I was hollerin and jumpin down the HWY and peoples thought I was bananas. I pulled over fast at a park and ride.
pwcracer
347
Hastings, MN, USA
Apr 16, 2007
  • Apr 16, 2007
I replaced the cap, and drove it a lot yesterday. It only once dribbled out about a quart of water, and it only did that after I parked it.. I am going to watch it very close, but so far think it might be ok.. At least I hope it is..
ProKiller
3,064
15
78
PA
Apr 16, 2007
#10
  • Apr 16, 2007
  • #10
if its only blowing out the overflow i don't think its a hg. it it was, wheres the break? if its between the chamber and water jacket, you'd have coolant in your chambers at idle/low rpms, and have white clouds out the exhaust. now you MIGHT have a head gasket that is on the way out and is only pushing it one direction when your into boost, but i doubt it.
OrangeMustangGt
1,976
Cape Cod, MA
Apr 16, 2007
#11
  • Apr 16, 2007
  • #11
hopefully its not, but i bet the hg's are gone...... I used to go through the same denialWHat ones did you use?
If you dont have them, get some cometic MLS ones....I changed 4 sets in a month untill i used them and even with knock they held fine!
F
Fopar
178
San Marcos, CA
Apr 16, 2007
#12
  • Apr 16, 2007
  • #12
actually you'd better hope it's the HGs if it's a stock block
Methodical
1,192
11
59
Clinton, MD
Apr 16, 2007
#13
  • Apr 16, 2007
  • #13
Do you have a sweet smell (don't know how else to describe it) coming from the exhaust?
pwcracer
347
Hastings, MN, USA
Apr 17, 2007
#14
  • Apr 17, 2007
  • #14
I had this happen before too, and it was the HG, but it was much worse, I switched the e7 heads out for the gt40's and went with a graphite Ford motor sport HG. I run 93 octane and never heard it pinging, the air/fuel was ok too..
I wonder if my block is messed up, if this is the second time in a row. I am running a better tune now than I did the first time tho..
I had purchased cometic, but didnt want to pull the engine to have their special machining done to the block to make them work..
The coolant looks good, not dirty or anything, and the level in the radiator is a couple inches below the cap, The over flow tank is 3/4 full right now with the car cold...
(I know that smell all too well )
DarkProphet
391
Quakertown, PA
Apr 17, 2007
#15
  • Apr 17, 2007
  • #15
Did you get your heads checked? My stock ones were warped, and It took me 3 sets of HG's to figure that out..
pwcracer
347
Hastings, MN, USA
Apr 17, 2007
#16
  • Apr 17, 2007
  • #16
I checked with a straight edge and a feeler gauge, is that enought? If they are warped,maybe I should get afr's
Trying to determine if I have a bad ECM; 98 Cobra
  • b4unoit
  • Aug 19, 2025
  • SVT Tech Forum
SVT Tech Forum Sep 14, 2025
b4unoit
  • dan50
  • Jul 18, 2026
dan50
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
