This is crazy what the $*#@ did I do?
69Rcode_Mach1
1,473
Salt Lake City, Utah
Okay I am trying to get this problem figured out. I put my battery in the car and almost have her ready to go. I had her outside so I figured ill give her a little rinse down and get the dust from all the sanding when I was prepping the engine bay for paint off the car. Now for the problem I went to make sure the windshield wipers worked while it was wet. Well I go and turn it and the starter engages and begins to turn the engine over. So I switch it off and then check and make sure the key works, well the key is in and it cranks over when I put it on start the way it should. Problem is that the car can now be started from two places and I have no wipers. (I recently swapped the car from a C6 and also built up the engine hoping to start her for the first time soon, also added a factory tach and rewired the clip in the back, all the guages work properly and NONE of the wires from the wiper or anything were touched I know that for a fact) Anyone heard of this problem before.
The key works exactly the way it should. It will crank if I try to start it. The problem is if I put the key to on or acc and then flip the wiper switch it will trigger the starter. I wired the solenoid exactly the way that it was before but to eliminate a possibility can anyone help me figure out how it should be wired. I have the positive cable from the battery hooked onto the left side and the starter cable hooked onto the right side of the solenoid. Then two wires hook to the front of it but I don't know what those wires hook to.
Here's an idea. Leave it the way it is, but figure out how to disable "Start". Then, you have a really trick hidden starter. No one would ever think to turn on the wipers to start the engine. Just don't drive in the rain.
I know I thought that would be an awesome idea also. Problem is where I live I have to have safety inspections so the wipers gotta work. I will try switching the two wires on the starter solenoid and see how that works since there is only two. I don't know what the wires on there are for. I will update you guys.
well it shouldn't crank but when i flip the key farther to ignition then it will crank. The key works perfectly normal. The wiper switch operates like the switch should it won't crank with the wiper switch unless the key is flipped onto on, or acc then i flip the wiper switch and then it will crank with that. I have two cranking options and no wipers you see what Im saying.
The 1969's have the reverse lights and neutral safety switch in a giant pigtail with two male ends and two females inside then it mates with one of two corresponding pigtails hanging on the firewall. They are not separate harnesses speaking of which I need to hook up my reverse lights.
I just think your car is possesed. that is the weirdest thing i have ever heard! I dont know how your wires would short together like that, but im sure its in the dash somewhere. they must be pinched. the wiper circuit isnt even related to the starter circuit.
I know that is what has me shocked. I redid wiring in the clip that hooks to the cluster, and none of thosewires have nothing to do with anything other than guages and lighting for them. I reconnected all the other wires back the way they were before. Now there is one thing, my voltage regulator has 4 metal tabs that connect into it - - - - In a pattern like the one you see. The one farthest to the left connect to some sort of small cylinder looked like a condensor you would find in a distributor. The wire broke due to old age, now the quest is figuring out what that thing is so i can get a new one and hook it up that is the only difference in the wiring there.
on the solinoid, try disconnecting the small wire on the right and see if the car still starts with the wiper switch. I know on my 68 the wire was brown. With many sorts of aftermarket ignition switch there is 12 volts going to the brown wire which didn't used to be there, and it can find ground through the solinoids ground path to the sheetmetal of the inner fender. if you have an aftermarket ignition you no longer need that wire anymore anyways. in any case it can't hurt to try real quick.
