This is what 13lbs does to a piston----pic
I had an old Cobra II that I did a engine swap in way back when. The mechanic that pulled the old engine took off the heads and found the imprint of a bolt in the piston. Bolt was nowhere to be found and the engine ran OK for what it was. Never figured that one out...
yikes :shock: Must have broke and slipped out the exhaust valve right away. Amazing that you didn't bend a valve or damage the heads.
I had a small hose clamp fallinto the #7 cyclinder on my 5.0 and didn't know it till it bent the pushrod, cracked the head, destroyed the top of the piston and chipped the top of the cylinder wall. Some of it was inthe combustion chamber, some of it was MIA and some of it is embedded in the top of the piston to this day.
Ouch, at least the heads were safe:nice:
I had a kid in my auto tech class last year who threw a rod in his thunderbird. We pulled the engine and after we cleaned up the antifreeze flood, we got the block apart. I think there was one intact connecting rod and no intact pistons. They were all broken in half like crackers. There was a nice sized hole about 1.5" across where the piston had punched through the side of the block and a big chunk of connecting rod in the oil pan pickup :rlaugh:
