  • 1994 - 1995 Specific Tech
this setup good for 400+ hp and tq
  • Thread starter Thread starter BlackPearl955.0
  • Start date Start date Apr 13, 2008
BlackPearl955.0
126
Blashyrkh, Wisconsin
Apr 13, 2008
  • Apr 13, 2008
any estimates or guesses how much this setup will make as far as hp and tq
I want 400hp+ and 400tq+ at the rear wheels WITHOUT N20
engine
Boss 302 block
Probe "streetfighter" 347 stroker kit
Forged I-Beam Rods, Flat Top Forged Probe Pistons, Steel Stroker crank, CL77 Bearings, Moly Rings.
custom ed c cam
AFR 185cc with nitrous port 58cc combustion chamber non emissions
VALVE SPRING UPGRADE PACKAGE, GOOD TO .600" LIFT
Victor 5.0 upper and lower intake
75mm throttle body
36# injectors
a fitting set of light weight roller rockers
28oz balance
cold air intake
new lighter set of lifters
long tube headers
Underdive pully kit
msd pro Billet distributor
ford racing 9mm wires
E3 dimond fire spark plugs
no smog or egr
85-200 wet shot
drivetrain
3.73 gears, traction lok, 31 spline axles
aluminum drive shaft
18" rims
Venom351R
4,548
41
98
MAINE
Apr 13, 2008
  • Apr 13, 2008
Iit will be tough. If I dont hit 400 with my new set up (Trick flow R intake and custom grind cam shaft) then there is no way that combo would. Im not going to pick up 60 RWHP so if your shooting for 400 at the wheels it will be tough.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 14, 2008
  • Apr 14, 2008
As long as you told Ed what you wanted, it should be real easy to hit 400hp.
BlackVert
5,589
9
98
Bethesda, MD
Apr 14, 2008
  • Apr 14, 2008
400 at the wheels shouldn't be too hard. but 42# injectors are probably called for ... after all, you are talking about 500 horses at the crank
Venom351R
4,548
41
98
MAINE
Apr 14, 2008
  • Apr 14, 2008
Yeah a lot of it will lie in the Cam. I think it will be close but interesting to see what that combo will pull off. Im currently having ED make a camshaft for me as well.
Black95GTS
1,644
Marlborough, MA
Apr 14, 2008
  • Apr 14, 2008
Easy. The tune might be interesting, but the power will be there. 36 pound injectors are no longer made, but 42 pound injectors are common, along with the OEM quality Ford LMAF, so you may want to think about buying that set and be done with it.
Adam
StinkinLincoln
240
Louisiana
Apr 15, 2008
  • Apr 15, 2008
400rwhp and just 185's?
sweet, maby i can see close to 340 w/ 170 eddys, 331 and a ots cam.
fastgtfairlane
266
  • Apr 15, 2008
i would just see what ed says. i dont know if the 185s are good for 500 horse at the crank out of the box. im sure with a good cam and some cnc ported 185s you should certainly be good then. you will need all of the supporting boltons and and a well thoughtout drivetrain for it too. you will also want a 3 inch exhaust and i would say 1 7/8 primary longtube headers to get there. that engine will have to really breathe to get there
Venom351R
4,548
41
98
MAINE
Apr 15, 2008
  • Apr 15, 2008
Im trying my best to get 400 at the wheels I wont know my numbers with my new set up until its all installed and dynoed sometime in mid to late May. Im hoping Ed grinds one hell of a nasty cam for me.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 15, 2008
#10
  • Apr 15, 2008
  • #10
What did you ask for when you emailed him? When I was doing my 347 3 years ago I was very specific in what I wanted. Ed's response was "Be ready, you've allowed me to go wild"
Venom351R
4,548
41
98
MAINE
Apr 15, 2008
#11
  • Apr 15, 2008
  • #11
I told him I wanted a cam that would pull in the RPM range along w/ the Trick Flow R intake and the AFR 185's and that Im trying to make s much HP as I can N/A. I know my Cobra intake is running out of steam long before the AFR's do in the 1/4 and I just want a cam that is going to produce the power to go along w/ the Intake and the heads.
BlackPearl955.0
126
Apr 15, 2008
#12
  • Apr 15, 2008
  • #12
yea im goin n/a as well. you guys think the victor 5.0 would be better or the trickflow r?
any 3" exhaust you guys recomend, and headers too?
rj95svt
422
Hayden, AL
Apr 16, 2008
#13
  • Apr 16, 2008
  • #13
I like the victor better but both are strong in the upper rpm's. The systemax II will make more torque than both of them but probably won't make the 400 hp your shooting for.
you may not make exactly 400 hp but you should be very close. I also think that the 42lb injectors are the way to go.
BlackPearl955.0
126
Apr 16, 2008
#14
  • Apr 16, 2008
  • #14
I found some kook long tubeheaders with 1 7/8" primaries to a 3" collector, but they are just over 1k for the ceramic coated. Also a prochamber offroad h-pipe for about 260. But I cant find a cat-back system that is 3" other then the Bassani with turn down tips or dumps. I like bassani but I want nice stainless tips out back, plus I want a more muscley, deep throat sound.
I think the pro-chamber will help with this but not sure or should I just find a regular offroad h-pipe that is 3"?
I want something like a flowmaster cat-back with some super 40's
does anyone have delta force 1 or delta force 40 and how do they sound?
Venom351R
4,548
41
98
MAINE
Apr 16, 2008
#15
  • Apr 16, 2008
  • #15
I dont think either one is better persay they will both produce big power and great flow numbers. Go with which one you lke more. I went with the Trick Flow R painted black b/c I think it looks awesome.
BlackVert
5,589
9
98
Bethesda, MD
Apr 16, 2008
#16
  • Apr 16, 2008
  • #16
kooks are not worth the money imo. too much leaking and they hang low
ask ed curtis what intake he recommends
P
2018 Rims on 1965 Mustang
  • PsuedoCode
  • Nov 15, 2021
2K
1965 - 1973 Classic Mustangs -General/Talk- Nov 15, 2021
PsuedoCode
P
Progress Thread finishing touches on my stroker build
  • doobismaximus
  • Jul 2, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2021
nickyb
347 Hp Estimate?
  • sixfeetunder6720
  • Mar 17, 2016
9K
Fox 5.0 Mustang Tech Mar 24, 2016
evolven
Realistic Hp/tq Expectations...
  • CT Grim
  • Sep 18, 2013
  • 2 3
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 27, 2013
FastDriver
  • Locked
Expired 1989 Mustang Ssp / Florida Highway Patrol - Procharged
  • bottlefedford
  • Feb 18, 2014
7K
Fox Body Mustangs For Sale (1979-93) Feb 28, 2014
Boosted427
