THIS SHOULD BE EASY
  • Thread starter Thread starter GREG91GT
  • Start date Start date Jul 1, 2004
GREG91GT
207
MISSOURI
Jul 1, 2004
  • Jul 1, 2004
my? is when i race my mustang up it revs very quick, but it dont rev down very quick, very slow going down whats my problem guys?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 1, 2004
  • Jul 1, 2004
Heavy drivetrain, such as a heavy flywheel, heavy tranny gears and clutch equipment. If you're in neutral and revving down, it's a combination of the heavy flywheel and heavy internal engine parts such as the pistons/rods/crank. It's sort of a fact of life...lol Unless you build a motor of primarily aluminum parts, including the flywheel, it's just going to be this way. It just takes less time to rev up because of the power of the combustion.
cardudeusa
1,744
Home of the Florida Gators!
Jul 1, 2004
  • Jul 1, 2004
Never thought of it like that.
GREG91GT
207
MISSOURI
Jul 1, 2004
  • Jul 1, 2004
no i no all of that, i mean its kind of like somthing is keeping it reved up for a while before it comes back down, in neatral
cardudeusa
1,744
Jul 1, 2004
  • Jul 1, 2004
It is designed to stay revved a little bit like 1500 until you come to a stop.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 1, 2004
  • Jul 1, 2004
Could possibly be a fuel delivery type of thing, like maybe your throttle stick a little? Or if you have a fuel pressure regulator, maybe it's running too rich or something...
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 1, 2004
  • Jul 1, 2004
Rotating mass is just plain fascinating....the weight of something that's spinning is (i dont remember the percentage) MUCH more than the actual weight of the object....sort of like taking a weight and tying it to a string, if you swing it around over your head it actually feels like it gets heavier the faster you swing it. If you get an aluminum flywheel and a small diameter clutch, your car will actually clime RPMs much faster and in effect will make your car gain speed faster, while at the same time will take more throttle to keep you at that speed, since the normal weight of the rotating mass will keep things spinning for a longer period of time, but with a higher amount of force required to get you there.
GREG91GT
207
MISSOURI
Jul 1, 2004
  • Jul 1, 2004
i thought it might be a idle air control problem, how does it act when this messes up?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 1, 2004
  • Jul 1, 2004
Mustangs will drop RPM from 1500 down to idle speed very slowly when you come to a stop. It is part of the computer design to keep the engine from stalling.
Sometimes the IAC which controls air bypassing the throttle butterfly will gum up and cause problems. Removing it and cleaning it with throttle body cleaner will often help.
GREG91GT
207
MISSOURI
Jul 1, 2004
#10
  • Jul 1, 2004
  • #10
mods
well this problem did not happen until i put all of my mods on like i have a 80mm c&l for 30s i have edelbrock heads,systemax intake, 75mm throtle body and spacer, and 1inch intake spacer,255lph holley pump,dss dish pistons,no ac,no ps,no smog pump,electric water pump drive,1 3/4 mac long tube headers, and a vortech s trim and fmu, s-trim not bolted on yet and a built c-4 with a 8inch ptc converter and pro stick shifter
Mavrick
2,264
Collingwood, ON
Jul 1, 2004
#11
  • Jul 1, 2004
  • #11
I thought that the computer kept the engine from dropping revs real quick, so that in between shifts your revs will still stay up?
On that note, I heard a video of an 85-86 mustang, and when shifting the revs would drop right down (im guessing 2000rpm or so from 5000), and man did it sound like crap.
GREG91GT
207
MISSOURI
Jul 1, 2004
#12
  • Jul 1, 2004
  • #12
any one else have any ideas
blk92stangg
583
Hawaii
Jul 1, 2004
#13
  • Jul 1, 2004
  • #13
Maybe vacuum leak.
GREG91GT
207
MISSOURI
Jul 1, 2004
#14
  • Jul 1, 2004
  • #14
i have checked for all vacum leaks and found none, i did find somthing today i am kind of inbaresed to say but my upper intake was loose well the bolts were any body ever had that to happen and how did your motor act i still have my problem after tighting it up
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jul 1, 2004
#15
  • Jul 1, 2004
  • #15
yeah mine drops a good bit when shifting too... i know what u mean
HISSIN50
34
129
Jul 2, 2004
#16
  • Jul 2, 2004
  • #16
stockish motor should pull between 15-20 inches of vac at idle.
good luck.
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Cyber Truck tried to race me!
  • MKatzenbach
  • Sep 5, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 8, 2026
gkomo
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
O
Suspension Extremely Quick / Light Steering
  • Okie
  • Oct 21, 2025
Fox 5.0 Mustang Tech Oct 22, 2025
AeroCoupe
