  • SN95 4.6L Mustang Tech
this sux
  • Thread starter Thread starter ooraceredgt
  • Start date Start date Sep 12, 2004
ooraceredgt
204
  • Sep 12, 2004
it seems that i cant get my car fixed by anyone. i've been havin some SES issues. i keep gettin a check engine light and getting a misfire code on a few cylinders ( usually 4 and 5 cylinder ) but sometimes its different cylinders. the car seems to lose power when it happens and it usually happens when i get the car around 70 - 75 mph. i took it to ford and they had it for 6 days and they couldnt figure out what it was doing. it still runs good when it isnt misfiring but when it misses and the ses light comes on it drives me crazy. has anyone had a problem like this :bang
mogs01gt
3,113
30
119
Ohio
Sep 12, 2004
  • Sep 12, 2004
well since you dont have really any mods. I would say its your tune. Try and take out the chip and see what happens.
krly79
464
VA Beach & So Illinois
Sep 12, 2004
  • Sep 12, 2004
I'd check the tune.
R
raykrv6a
153
Maple Grove, MN
Sep 12, 2004
  • Sep 12, 2004
What tune is in your Predator? The latest if R50A. I'd download it and update your Predator. If course, you need to go to Radio Shack and get the power supply, plug, and cable to update your Predator from your desktop.
About 40 bucks total.
After I downloaded R50A, I noticed a second tune on my Predator called
Ford HP Tune. I believe you can modify and install it also.
Easy test to see if it's tune triggering something is to restore your stock tune and run it a few days to see if you have the same problem.
Ray
ooraceredgt
204
  • Sep 12, 2004
Ray
i tried it with out the tune also and i still get the ses light. i will try to see if the other predator tune will help it
mogs01gt
3,113
30
119
Ohio
Sep 13, 2004
  • Sep 13, 2004
Did you remove the negative terminal for around 10 minutes?
bluegt02
9
  • Sep 13, 2004
My 3rd cylinder did this to me on my 02 GT the other week and made a weird noise when i went to 3rd... Took it to ford and they had to send the head off or somethin b/c it had locked up. Maybe this helps, also look at checkin ur spark plugs
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 13, 2004
  • Sep 13, 2004
have you checked you spark plugs and the coils? the SES light flashes when the misfire happens because the computer is warning you that you are damaging your cats.
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
R
Misfire at high rpm! Help
  • Ryanm2018gt
  • Jan 2, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 17, 2026
highplace11
H
