I'm getting a set of Trick Flow TW heads. I'm planning on using a TF stage 1 cam, but I'm just curious to see which you guys that have them are running. Are you happy with it? How's the low end torque? How does the idle sound? ect.... Thanks.
Keep in mind you'll need new valve springs with your TW heads, unless you buy track heat heads which have good springs already with 10* locks and retainers!Chris6050 said:I'm getting a set of Trick Flow TW heads. I'm planning on using a TF stage 1 cam, but I'm just curious to see which you guys that have them are running. Are you happy with it? How's the low end torque? How does the idle sound? ect.... Thanks.
Chris6050 said:Ok I guess I'll check into the springs. It's funny because that's what I was originally told, then I posted about it here a couple days ago and a couple people said that the springs are fine.
Grn92LX said:The stock TW springs are fine for most aftermarket cams. Once you get into real cams with faster ramps and higher lift is when you need them. A tfs 1 cam is more than fine for stock TW springs.
