Those with 4.10 gears, questions
99FiveOh
2,051
20
99
J-Ville, FL
I aquired a 94 GT that needs a little work to get it road worthy. Since the body is in perfect condition I'm going to use parts from my current 94 GT to get this other one on the road.
The person I bought the car from said it had 4.10 gears in it as well as a fully rebuilt trac-loc. Is there a big difference between 3.73's and 4.10's? I'm used to driving around with 2.73's, will there be a big difference?
I'm not too concerned with fuel economy with this car, I just want something that's snappy. I've never had or ridden in a car with this much gear and wanted some insight on what to expect. Mainly because I have the option of swapping my 2.73 geared rearend into the new car.
You see a lot of talk about the difference between 355's & 373's :crazy:
You ask about the diff between 373's and 410's :scratch:
Just use your common sense and do the math ;)
It don't take a mental giant to see there is a good bit more of a jump
with what you speak of here
Now ... A rule of thumb with gear ratios is ...
1/4 of a turn is very subtle or barely noticeable
and
You gotta go about 1/2 of a turn to notice much difference
therefore
Your perspective of driving around with 273's and jumping up to more
than 1.25 of a turn is going to make a VERY BIG difference to you :Word:
Grady
Well from the years of reading information here and on other sites and stang rags, I was quite sure the jump from 273 to 410 would be huge. I guess I was just wanting to hear how folks were getting along with their decisions' on the 410's.
Well ... Gears like other hot rod parts :)
They should be selected based upon application :nice:
As I see it .........
Two main points are to be looked at when talking gear ratios
when you are talking about a street car
1 Highway use
2 How the car has been or is to be modded
Lets start with 1 first
No matter what you do to the car .........
you'll highway cruise at a rpm based upon ratio and tire size
This is not open to debate or opinion :nono:
Its really nothing more than simple math ;)
Now that we've put that to rest
How about looking at #2 and lets stay with a NA application
If this thread goes into a pa application ......
somebody else can take the ball and run with it :D
Torque Curve or Power Band potential comes into play here :Word:
Two examples to help explain
Stock Stang
H/C/I Stang
We all know the powerband of a little stocker Stang
It starts to peter out before 5K
Our h/c/i Stang will have two very different powerband aspects :)
a) It has been shifted up
b) It has been extended
This needs to be seen because a steep set of gears will act very
differently in each of our example Stangs here
You see ... Our h/c/i Stang example will have around 1K or perhaps a bit
more additional rpm to work with that the little Stang just doesn't have
You put a steep set of gears in a stocker and it just whips through
the gears cause its powerband is so short
That is why you often see peeps on these forums crying about
how their 1st and 2nd gears are too quick :cry:
And as we said above in this post .........
If you go to the strip a lot
or
You are a pa kind of guy
Those applications will dictate some considerations of gear choice
Summing up ... It is my hope to show that the same gear set is not
optimum for all applications :D
Grady
I'll open it up for debate. Selecting a gear ratio is easy. Your car should cross the traps at the top end of the rpm band in 4th gear. So, just do the math, and figure out what mph you will run, and what gear ratio you need to accomplish that. If your car does not feel strong enough on the street, just put a bigger set of heads, or a bigger cam in there till it feels appropriate.
That being said, 4.10s over 2.73s???? That's a no brainer. 2.73s make a Mustang feel like dog****.
Kurt
SO I feel I can speak well from experience on this one since I have a fox with each, and both are essentially stock foxes.
3.73s Feel great in the 87. orig 2.73 aka grandma gears, and the difference was huge, yet on fwy can still cruise at 70 without the drone. DECENT around town manners, but put down the hammer and she wakes up.
235/4517 FRONT
275/40R17 REAR
4.10s while awesome for those short bursts of aggro are fun, rowing gears light to light and hwy cruising is a bust, and thats with 245/45R17s. Cant imagine what it would be with a shorter tire.:eek: PLUS JAM ON THE GAS AND WATCH THE GAS GAUGE DROP.
FWIW I run 3:73s with the power adder. 4:10s wouldve been too much gear on a 26" tire through the traps forcing me to run into 5th.
Sometimes I wish I'd have gone 3:55s for a little more highway topend though....top of 4th is kind 'it' on a t-5 if you ever partake in such illegal roll-on activities heh. 5th is useless and gay.
This is the info that preceded the statement
Just wanted to make sure it was clear that ....
just that bit of info only was what I was talking ahbout
and
I did not want to cause peeps not to continue in the discussion
Grady
