Those with adjustable shocks/struts come in...
Some are on the top of the strut, where the strut goes thru the c/c plate, and other like Strange are down at the base of the strut.
Lil dials you turn usually from say 1-10 going from softest workin up to hard settings
I have the tokico 5ways, the fronts will be easy to adjust but the backs are going to be a little harder. They are in the trunk behind all the side molding. If you leave it off, they won't be hard to adjust.
VibrantRedGT said:
The Strange ones I have like Eades mentioned are at the bottom. It's not hard to get to only problem is you have to do it by feel not by sight.
The easiest way I found to adjust the strange is to turn the wheel to full lock in one direction and do one, and then turn the wheel the other way and do the other one.
i have tokico d-specs are theyre very ez. the set comes with a tool that can go on ur key chain and u adjust em from the top. i can do all 4 in a 2-3 minutes.
