69clark Founding Member Sep 25, 2002 731 7 18 Ravena, NY Jan 31, 2007 #1 Jan 31, 2007 #1 On a 90mm TB is the mounting holes the same as those of a 75mm. So basically if an intake manifold is made to accept a 90mm TB can I bolt up a 75mm TB for the time being or do I need to use a 90mm.
Bosko5.0 Active Member May 18, 2006 1,067 0 37 longwood, FL Feb 1, 2007 #2 Feb 1, 2007 #2 90mm you should be able to bolt up a 75mm just measure the distance between the bolt holes to be sure
69clark Founding Member Sep 25, 2002 731 7 18 Ravena, NY Feb 1, 2007 #3 Feb 1, 2007 #3 I can't measure it because I don't have the intake, I need to know before I buy something I can't use.
Grn92LX Fidanza Man! Founding Member Jan 14, 2001 6,819 64 129 New York Feb 1, 2007 #4 Feb 1, 2007 #4 Should all bolt on regardless of size.
69clark Founding Member Sep 25, 2002 731 7 18 Ravena, NY Feb 1, 2007 #5 Feb 1, 2007 #5 Thats what I thought.
Bosko5.0 Active Member May 18, 2006 1,067 0 37 longwood, FL Feb 1, 2007 #6 Feb 1, 2007 #6 i was unsure i didnt have my dig. caliper to measure the opening of the 75mm throttle body on my table.
5spd GT "the 5.0 owns all" Founding Member Aug 7, 2002 9,516 6 99 Arkansas Feb 1, 2007 #7 Feb 1, 2007 #7 It will bolt right up. The bolt pattern location is the same. The intake opening is nothing more than the "casted out " diameter, it is not a reason to choose throttle body size or application.
