Thoughts on harnesses?
Stock replacement or Corbeau Harness?
  • Stock
    Votes: 0 0.0%
  • Total voters
Looks like those are meant to work with existing corbeau seats. Assuming you have those with the necessary harness holes through the top of the seat back, they look like a really nice option.
To use without a harness bar, the mounting point should ideally be near shoulder height and straight back behind the seat. To use the rear lapbelt anchors, the straps may angle down too much to not use a harness bar; they should not be more than 45 degrees from vertical from the seat back to the anchor or where they cross the bar. Optimal strap angle is less than 20 degrees which is also the standard for most racing rules. And of course having the shoulder straps coming off the rear seat will make the rear seat unusable.
I'm absolutely not a fan of systems like those that have 2 shoulder belts and no sub-belt. There's nothing holding the lap belt down low against your hips when the shoulder belts receive force tension in a crash. Leads to scrambled abdominal organs.
the stock 3-point is essentially self-tightening because forward motion of the torso in a wreck causes the lap portion of the belt to tighten. They also allow the upper body to move to the side in the event of a collapse 4-points do neither of those things.
