Throttle blade orifice issue
  • Thread starter Thread starter bjmellon
  • Start date Start date May 7, 2004
bjmellon
23
PA
May 7, 2004
  • May 7, 2004
Hey guys, i'm new to this ford thing. I recently bought a used tb - 70mm. My problem is that my idle is high due to the size of the hole in the throttle blade. It appears that someone previously drilled it oversize (why i dunno).
My question to you all is; where can find a plug for this hole?? I have tried everywhere with no luck, I know they exist but can't find 'em. Any help/comments would be greatly appreciated.
powershift351
225
Carlsbad, Ca.
May 7, 2004
  • May 7, 2004
how high is your idle?
dvs bullet
326
Ontario, Canada
May 7, 2004
  • May 7, 2004
I took the advice from a magazine on what hole size to drill, and did it. The idle was then around 1500 to 1800. So what I did was weld the hole and grind it flat and them drill another in a different spot. It was pretty stupid to drill big in the begining, but you learn from your mistakes. Anyway it hasn't given me a prob yet, and that was over a year ago. if it helps
bjmellon
23
PA
May 7, 2004
  • May 7, 2004
1100,, this is definetly the cause. While trying to diag this i found; slight vacumm leak at pcv hose, tps sticking, and carboned iac passages. If I place tape over the hole I can bring the idle down... No vacuum leaks, idle screw is bottomed out, and Iac is properly functioning.
bjmellon
23
PA
May 7, 2004
  • May 7, 2004
I thought of that, but feel weary of the longevity.. Have you had any problems.
I also thought of using lead and pounding it over the hole.. What's your feeling's on that..... Thanks for the reply
88stangmangt
2,332
Stafford,VA
May 7, 2004
  • May 7, 2004
people do this because when running big cams some times if the idle drops it will stall. this could happen comeing to a complete stop,WOT or just idleing you could weld it back up and drill it back out to stock but i wouldnt cover it up as it has a hole stock for idle issue's anyway. GOOD LUCK!!
bjmellon
23
PA
May 7, 2004
  • May 7, 2004
Makes sense, do you happen to know the stock size?? Thanx for the info
88stangmangt
2,332
Stafford,VA
May 7, 2004
  • May 7, 2004
wow lol no i dont know off the top of my head i got my stock TB in a box tucked away in the shed. im sure some one here can chime in and tell you.
bjmellon
23
PA
May 7, 2004
  • May 7, 2004
Thanx a lot guy's, I'm going to take it in to work and weld it first thing tomorrow morning. I'm thinking i'll just pop on one of the iac bypasses instead of drilling the hole. Thanx again!!!
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine 1990 5.0 bogs and pops over half throttle
  • Sander
  • Aug 1, 2025
Fox 5.0 Mustang Tech Aug 2, 2025
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Vortech V3 Si - Bypass Valve to BOV swap issues
  • seanmahoney
  • Jun 26, 2025
SN95 4.6L Mustang Tech Jun 26, 2025
seanmahoney
