I was thinking about this whole intake thing and I thin that going with the C&L plenum and the Accufab TB would be the best because C&L is developing the lower intake to match. From reading those results on the test I'm very curious about 70mm vs. 75mm because those test seemed to indicate that the 70 performed better. Does anyone know when you switch TBs can you no longer use the normal fitting CAIs or Densecharger type things?
Graham
