THrottle Body and Intake
  • Thread starter Thread starter GATOR98GT
  • Start date Start date Feb 16, 2004
G
GATOR98GT
185
BRISTOL
Feb 16, 2004
  • Feb 16, 2004
A friend on mine has a 91 gt. The car is stock except for some flows and a k&n filter. WHat would be the best throttle body for a basicaly stock setup?
What would be the best size 65 , 70 , or 75. Also what brand should he go with?
Another question is on the intake. What would be a better intake for this same setup a Cobra intake or a Trickflow?
Any suggestions would be a great help.
schoonover_88
189
  • Feb 16, 2004
Deffinately 65mm. I hear it can handle up to 400HP or something like that. As for the intake I would go with the Trick Flow.
P
proxses
620
Dayton, Oh
Feb 16, 2004
  • Feb 16, 2004
I know this is not quite what you are asking, but....
GEARS, GEARS, GEARS!
If your friend can get them all at the same time, he would see a world of difference.
Or maybe get the gears instead of the intake.
Not what you were asking, I know.
But something to tell your friend.
Oh, and I like Trickflow as well.
gaslight
3,365
Maine
Feb 16, 2004
  • Feb 16, 2004
that trick flow might be too big for the stock heads and cam.
I also vote GEARS. THen throttle body and EGR spacer.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Feb 16, 2004
  • Feb 16, 2004
if your friend plans to add more power in the future go 70, otherwise, go with a 65
H
horseplay91
283
Lake in the Hills, IL.
Feb 16, 2004
  • Feb 16, 2004
i vote in keeping the stock throttlebody and spend the money elsewhere. subframes, gears, suspension, exaust. oh man! i could come up with TOO many things where id put the money.
H
Highbredcloud
1,075
Palos Hills, IL
Feb 16, 2004
  • Feb 16, 2004
If he is set with getting a TB and intake...than a 65mm TB(accufab or FORD RACING) and a GT-40 style intake are perfect for stock mustangs since they are torquey intakes...However, I would go ahead and get a mAF as well...it's an expensive way to add 15HP and there are better ways to spend the money on such as mentioned above...GEARS...
T
Tommy91Stang
31
Glenolden
Feb 16, 2004
  • Feb 16, 2004
i am the firend that wants to do this i have 373 gears and plan on getting a e 303 cam but i dont know when i am going to get the cam could be a year should i go with the 65 for now then go to the 70
H
Highbredcloud
1,075
Palos Hills, IL
Feb 16, 2004
  • Feb 16, 2004
65mm TB is a good size and will be plenty while allowing good low end throttle response...
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
