throttle body and mass air install
5literstang
1,374
Clark, NJ
hey i have a BBK twin 65mm throttle bady that id like to put on, please tell me is there anything kind of troubles il have just bolting it up? also i have a 90mm mass air that id like to put on, would i have any problems? does it have to be calibrated to the injectors i have? the car is a 99 cobra by the way...thanks -Jeff
is it a lightning MAF? If so then you can have it adjusted through your computer, if its aftermarket they use sample tubes to trick the computer into thinking it has something different...not as good as a direct computer tuning. Find a SCT dealer etc to get a tune.
ok well i did do the tb, and the cable seems too tight and the gas pedal kinda sticks at like 1300 rpm's and then it goes back to normal...could it just be the TPS? should i jsut try adjusting it somehow? also how should i adjsut it? thanks...im jsut goin to wait to put the MAF on when i put my blower on that way i can jsut get it tuned....
anyone? well i put the stock thorttle body back on cuz of that problem...but i called up BBK and and they told me to file out the hole so it fits better...so i guess thats what im goin to do...anyone else had this problem with the BBK throttle bodys and DOHC? thanks
