throttle body install
BigHoss91GT
11
Hey everyone, i need some help here. I got a 65mm TB off of my neighbor and i want to put it in and i was wondering if it was difficult or anything or if I would run into any problems and he said something about resetting voltage??? Any help is greatly appreciated.
Thanks
Brad
Well, the difuculty begins with you... Do you have tools? Any experience? If so than TB's are cake man. Just make sure you have two of the gaskets, there is one on either side of the egr plate. I am sure someone will post a step by step if you wait long enough.
Ps> there will be some coolant lost, albeit a very small amout. Have some towels handy.
Good luck man, and most of all have fun. :nice:
Oh no!!
Curse said:
Its simple, just make sure you have all the gaskets. You have to set the TPS voltage with a volt meter. Good Luck :nice:
I replaced mine with a 70mm throttle body and never reset anything...oh no, help me out what was I supposed to do and how do i do it?? thanks
red probe from meter to green wire on tps/blk probe from meter to blk wire on tps-loosen tps-turn a small amount untill you get .98v,dont have to be exact just close,this is with key on engine off.You might have to make atleast 1 of the holes bigger so you have more adjustment.After done,move the throttle to full open slowly and the volts should go up to around 4.6v at full open.When all done,disconnect battery for 20 minutes or so then reconnect-your good to go.
