Throttle Body Question/Advice
  • Thread starter Thread starter mystangruns10s
  • Start date Start date Jan 27, 2007
M
mystangruns10s
  • Jan 27, 2007
I am planing on buying a new throttle body for my 93 GT but Im not sure what size to get. I know that current and future mods need to be accomidated for in choosing, so Ill break it down a bit. 93 GT, K&N CAI, SN95 70MM MAF, stock upper lower intake, injecters, heads, cam, ect. MAC headers, off road H pipe, flowmaster 40 series dumped, gears, pullies, MSD blaster, and some other stuff. I have been doing some reading and people say getting too big of a throttle body hurts low end torque. I also read in the 50 performance handguide that your TB should always be bigger then your MAF. But in the future I plan on getting a cobra upper/lower intake. I am currently doing the junkyard budget build, and I was going to get a 65MM TB off an explorer, but then my TB would be smaller then my MAF. So with my current set up, what would be the best TB size to get, 65MM, 70MM, or 75MM. I was also wondering what size TB the stock EGR spacer will accomidate? If you get a 70 or 75MM do you also have to replace the EGR spacer? Also if anyone knows the size of the TB on a cobra upper/lower intake I was thinking I may as well just get that size now, and sufffer losing some low end torque in the mean time on the current set up until I get the intake. Any help would be appreciated. Thanks
ronburgundy
179
BC coast
Jan 27, 2007
  • Jan 27, 2007
65 should be fine for now, keep in mind if you go big on the throttle body your gas peddle becomes more of an on/off switch.
M
MustangOwner
Banned
Dec 13, 2006
160
  • Jan 27, 2007
Hey what do you mean the gas pedal becomes a on/off switch?
tom23
55
CT
Jan 27, 2007
  • Jan 27, 2007
Yea what does that mean?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jan 27, 2007
  • Jan 27, 2007
It doesn't become and on/off switch. I love my 75mm tb.
Now if you're on a budget, get that explorer 65mm and make it work. If not, get a 70mm and make sure it matches your cobra inlet.
A bigger tb does NOT lose low end torque!!!!!!
M
mystangruns10s
  • Jan 27, 2007
Does anyone know what the TB size is on the cobra upper lower intake? I do want to stay on a budget but Id rather buy the right size ( 70 or 75) the first time and not have to replace it when i get the cobra upper/lower intake, esp if there is not going to be a loss in low end torque in the mean time on the current set up
93gtmustang
524
43
49
Jan 27, 2007
  • Jan 27, 2007
Your throttle body should be smaller than your MAF Meter.
For example, 76mm MAF with a 65mm or 70mm throttle body would be ideal.
You want to have a funnel effect from the MAF to the throttle body.
I'd go with the 65mm throttle body for now.
If you install a supercharger, you'll have to go with a larger MAF, throttle body and injectors. As well as a larger fuel pump.
F
fast4cheap
82
north carolina
Jan 27, 2007
  • Jan 27, 2007
I have a 70mm throttle body on my 93 it has a cobra intake and it fit fine. It also performed very well for my mild mods, I think it will perform at higher levels to.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jan 27, 2007
  • Jan 27, 2007
70mm is the right size, a cheap junkyard 65mm is the budget size. Unless you can find a cheap used bbk 70mm in the classifieds.
jtfairlane
468
#10
  • Jan 27, 2007
  • #10
The 1993 5.0 Cobra motors came stock with an F3ZE-AA 65mm throttle body.
The Cobra intakes do not use a separate EGR Spacer, it is built into the intake, so all that is required for the Cobra intake is the throttle body.
If you are going to get a new throttle body for your stock intake now, you need a matching EGR spacer. So yes, if you buy a 70mm throttle body, you want a 70mm EGR spacer, 75mm TB and 75mm EGR spacer, and so on. Also, for maximum performance, when adding a larger than stock TB like a 70mm or 75mm, you want to check the size of the opening on the upper intake manifold. Ideally, it would match the size of the egr spacer and throttle body so as not to disturb airflow. For example, on stock 5.0 H.O. upper intake manifolds the opening matches the stock 60mm throttle body and is smaller than most aftermarket sizes, it's best to take a die grinder to the opening and carefully match the size of your egr spacer, using the new egr spacer's bore as a template.
V
v8only
2,378
22
49
Jan 27, 2007
#11
  • Jan 27, 2007
  • #11
a 65 is all you need for your future combo, no more. while you could do a 70, I wouldn't suggest it, as well, there is quite a debate about going too big a throttle body, I personally wouldn't do it. I was helping someone out on a board who had a 75mm tb on a bone stock stang, I told him to remove it for a stocker, and he said it made a night and day difference. On a budget, go for the modified explorer tb, it'll be fine.
ronburgundy
179
BC coast
Jan 28, 2007
#12
  • Jan 28, 2007
  • #12
i had a 70 on my almost stock 93 gt. i found it to be quite touchy for around town driving or stop and go traffic, that's why i said it turns your gas pedal into more of an on/off switch. especially when your cable and tb are a tiny bit sticky against the idle stop. my wife thought i had a nervous 'tap on the knee habit' when i drove around until she tried it. the first few times those tires were howlin every time she took off. expensive michelin's too.
M
mystangruns10s
#13
  • Jan 28, 2007
  • #13
Does anyone know what the size of the opening is where the throttle body connects on a cobra upper and lower intake? "The 1993 5.0 Cobra motors came stock with an F3ZE-AA 65mm throttle body.
The Cobra intakes do not use a separate EGR Spacer, it is built into the intake, so all that is required for the Cobra intake is the throttle body. "
If the intakes only need the throttle bolted right up to it, I would think they should match in size? The question is what size are they?
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
D
Throttle Body Spacer
  • dropteeth
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
nicholase
