- Apr 26, 2004
- 373
- 0
- 0
I need to know what is involved with installing a new throttle body. I hear I can get around 10 HP doing that. Is it an easy mod that's worth doing?
Also, I read somewhere that it takes care of the slack in the gas pedal also. Is that true?
I have a K&N FIPK. Will it work with a newer throttle body if I installed one, or would I have to get another tube with a bigger opening for it to attach? Or should I get the same MM size?
Thanks!
Thanks!
No way you'll get anywhere near 10 with just a TB swap. And as KaPPaBaLL said, don't bother if you're not swapping out the plenum as well. Even this will only get you about 4-8 RWHP, at best.
