Throttle HELP??
  • Thread starter Thread starter nos707
  • Start date Start date May 24, 2007
nos707
108
UK
May 24, 2007
  • May 24, 2007
Hi Guys,
I have this problem! It happend once before, but now its all the time!
If I stamp the throttle hard...nothing happends!
If I push into it, it accelerated hard, but If I try to stamp the pedal fast...nothing!
Revs just drop to idle untill I back off and push into it again!
Im thinking TPS needs re-setting??
What do you think?? :SNSign:
cjones
1,561
Avondale, AZ
May 24, 2007
  • May 24, 2007
what is the TPS reading at close throttle and at WOT??
does it cutout anytime you are at WOT??
nos707
108
UK
May 25, 2007
  • May 25, 2007
I haven't checked the TPS voltage yet!
It only happens when I stamp on the pedal fast! If I push into it its fine!
nos707
108
UK
Jun 8, 2007
  • Jun 8, 2007
Ok, so checked the voltage....I clicked the ignition ON and then checked using the green wire as live, and earthed off a bolt on the body.
Voltage was 1.7v. loosened the 2x screws and rotated the TPS till I got .99v.
Started the car but ran rough!! The idle had dropped off from 1100rpm to around 700rpm, and Wouldn't rev!
But if I then adjust the idle back to 1100rpm, wont that then change the TPS reading again??
Am I doing somethig wrong??
Do I have to set the idle/throttle body first?
What do you think guys??
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 8, 2007
  • Jun 8, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is less than $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
nos707
108
UK
Jun 8, 2007
  • Jun 8, 2007
Hi jrichker,
The problem is i am using engine management with a new ECU.
So this probably wont give me any codes even though the stock ECU is still pluged in and working with the new one!
Do I have to set the butterfly in the throttle body first, then adjust the TPS?
Or am I doing something wrong?
I checked the voltage with the ignition on so the fuel pump was buzzing, was that right?
bandmc
29
  • Jun 8, 2007
New MAF?
vristang
4,933
101
124
Seattle
Jun 8, 2007
  • Jun 8, 2007
nos707 said:
Hi jrichker,
What 'Engine Management' unit are you using?
How it interacts with the factory ecu could prove to be important.
Still try to pull the codes.
I would think that if the TPS is the cause of this problem, then you won't be able to see it when checking the tps with a DVM.
You could also stick a DVM on the tps wire near the ecu. Take the car out for a drive and watch the tps signal when you mash the throttle.
If you do this, use caution...
jason
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
D
Engine Why is my fox body throttle not smooth
  • dqureshi06
  • Aug 7, 2024
Fox 5.0 Mustang Tech Aug 10, 2024
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
