Throttle position sensor stuck at 5 volts
What can cause my throttle position sensor to always read 5.2 volts, I swapped it 3 times one after another thinking it was the tps itself with the same results on all three.
Believe it or not the car runs fine with the exception of some hesitation when it’s cold but after it warms up it will run like a champ all day with no problems.
It’s a 87 GT with a MAF conversion and all sorts of mods. Cam, exhaust ,TKO tranny, 3.73 gears, 4 wheel disc break 5 lug conversion,ext.
Any tips will be greatly appreciated .
TPS setting and troubleshooting
Revised 06-Oct-2010 to add open computer signal ground information.
Setting the TPS:
You'll need a good Digital Voltmeter (DVM) to do the job. Set the TPS voltage at .5- 1.1 range. Because of the variables involved with the tolerances of both computer and DVM, I would shoot for somewhere between .6 and 1.0 volts. Unless you have a Fluke or other high grade DVM, the second digit past the decimal point on cheap DVM’s is probably fantasy.
Since the computer zeros out the TPS voltage every time it powers up, playing with the settings isn't an effective aid to performance or drivability. The main purpose of checking the TPS is to make sure it isn't way out of range and causing problems.
Wire colors & functions:
Orange/white = 5 volt VREF from the computer
Dark Green/lt green = TPS output to computer
Black/white = Signal ground from computer
The Orange/White wire is the VREF 5 volts from the computer. You use the Dark Green/Lt green wire (TPS signal) and the Black/White wire (TPS ground) to set the TPS. Use a pair of safety pins to probe the TPS connector from the rear of the connector. You may find it a little difficult to make a good connection, but keep trying. Put the safety pins in the Dark Green/Lt green wire and Black/White wire. Make sure the ignition switch is in the Run position but the engine isn't running.
When you installed the sensor make sure you place it on the peg right and then tighten it down properly. Loosen the back screw a tiny bit so the sensor can pivot and loosen the front screw enough so you can move it just a little in very small increments. I wouldn’t try to adjust it using marks.
A.) Always adjust the TPS and Idle with the engine at operating temp. Dive it around for a bit if you can and get it nice and warm.
B.) When you probe the leads of the TPS, do not use an engine ground, put the ground probe into the lead of the TPS. You should be connecting both meter probes to the TPS and not one to the TPS and the other to ground.
C.) Always reset the computer whenever you adjust the TPS or clean/change any sensors. I just pull the battery lead for 10 minutes.
D.) The key is to check the TPS voltage whenever the idle screw is changed.
TPS testing:
Most of the time a failed TPS will set code 23 or 63, but not always. Use either an analog meter or a DVM with an analog bar graph and connect the leads as instructed above. Turn the ignition switch to the Run position, but do not start the engine. Note the voltage with the throttle closed. Slowly open the throttle and watch the voltage increase smoothly, slowly close the throttle and watch the voltage decrease smoothly. If the voltage jumps around and isn’t smooth, the TPS has some worn places in the resistor element. When the throttle is closed, make sure that the voltage is the same as what it was when you started. If it varies more than 10%, the TPS is suspect of being worn in the idle range of its travel. It should go from base voltage at idle to somewhere near 4.6-4.8 volts at WOT [/b]
TPS Troubleshooting:
The TPS sensor is a variable resistor like the volume control on most cheap radios. We have all heard them make scratchy noises as you turn them up or down. The carbon element can wear and cause a drop out spot in the output voltage. This confuses the computer because it expects to see a steady TPS voltage increase as the Throttle opens up.
TPS troubleshooting steps:
Some basic checks you can make to be sure that the sensor is getting power & ground:
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter.
Check the resistance between the black/white wire on the MAP/BARO sensor and then the black/white wire on the EGR and the same wire on the TPS. It should be less than 1 ohm. Next check the resistance between the black/white wire and the negative battery cable. It should be less than 1.5 ohm. More than 1.5 Ohm means you either have wiring problems or a open signal ground inside the computer. An open signal ground inside the computer will disable the TPS, EGR, ACT, ECT and MAP/Baro sensors. That will cause performance and drivability problems.
See http://forums.stangnet.com/749974-computer-issue.html for more help on fixing the computer innards.
The following power on check requires you to turn the ignition switch to the Run position.
Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or EGR sensors. Use the black/white wire for the ground for the DVM.
No offense, but are you sure that you're testing it correctly (ie probing the correct wires)? Because 5v should be the reference voltage and should be always present on the O/W wire when the ignition is on.
Read through jrichker's post carefully, paying close attention to what wires you should probe on the TPS. It seems waaaaay unlikely that you'd have 5v output from the TPS with multiple sensors, unless the harness was cut elsewhere and spliced back together improperly.
With the ignition on and engine off, open the throttle with the gas pedal then release it, this should reset the tps. I read somewhere that the tps is self adjusting on our cars and that there is no need to set it with a dvom. I've
tried this on my car to see if it works, and i have reset my idle and cured my idle probs without manually resetting tps. I think if you reset the idle by loosening or tightening the adjuster screw you have to adjust the tps, however, the ecm controlls the idle. If you reset the idle then floor the pedal, will it will read the input from the tps and adjust it automaticaly?
