Throttle Stuck
  • Thread starter Thread starter 93calicobra
  • Start date Start date Sep 15, 2006
9
93calicobra
  • Sep 15, 2006
so it seems my throttle is stuck. not only when i start do the rpms jump up to around 2k but when I am driving I can take my feet off everything and the car will drive itself at 2k rpms. I can feel the car jerk back and forth a little when I come to a stop and the rpms start to drop but as soon as I push the clutch in then the rpms jump back up. Is this a quick fix? is the throttle cable pinched or something? someone help.
ps - every now and then it will become "unstuck" and act normal.
TrophyHead
1,195
11
49
PA
Sep 15, 2006
  • Sep 15, 2006
I would get some white lituhium grease in a spray can. You can get at any autoparts store. Move the spring located under your throttle body with your finger back and forth and cover it with the grease.
Make sure your cable is in a nice sweeping pattern with no tight bends in it.
How's your idle?
QUIKSVT
93
  • Sep 15, 2006
its not his throttle cable, its his Idle Air Control...
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Sep 15, 2006
  • Sep 15, 2006
IAC needs to be cleaned. Also clean the Throttle Body while you are there. Then dissconect battery and reconnect after a few minutes and let the computer learn how to idle again.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 16, 2006
  • Sep 16, 2006
Clean or replace the IAC, check/reset TPS voltage, reset idle, and pull codes. If you have an aftermarket throttle body, it may be sticking, but chances are you're having issues with the IAC. Check out this thread for everything you ever wanted to know about a surging idle, and the solutions for it.
QUIKSVT
93
  • Sep 16, 2006
man, is there an echo in here?
BlownFiveLiter
18
108
Chicagoland
Sep 16, 2006
  • Sep 16, 2006
Common problem
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
N
Sticky Throttle
  • NooStang
  • Jun 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
General karthief
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Fuel FMU stuck?
  • JD1964
  • Sep 16, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
JD1964
