throw out bearing replacement
MacDiesel
74
my 98 cobra needs a new throw out bearing. i know it is dumb to change the throw out bearing without changing the whole clutch kit, but i am selling my car and i just want to make it right without replacing everything and spending the extra money just to sell it. my question is..do i have to drop the h pipe in order to pull the transmission back enough to change the throw out bearing??
Yep, tranny has to come out to replace the TOB. It cannot be replaced by only "backing" the tranny out. Has to come all the way out from the clutch. Yep, H-pipe has to come out, too. It's not terribly difficult, just lots of work and several hours. You will probably need something to jack it back up unless there are two of you to "muscle" it back up. Oh, and be careful, don't let it "hang" on the clutch if you get tired as it's possible to warp the clutch center and get good chattering.
There's pretty much consensus that the Ford TOB is about the best quality.
Good luck.
