Throw Out Bearing?
  • Thread starter Thread starter 7upstang91
  • Start date Start date Dec 17, 2009
7upstang91
936
124
74
Florida
Dec 17, 2009
  • Dec 17, 2009
Throw out bearing? Whines when driving? Coming from the tranny. I have not personally heard the noise coming from my mom's 01 Cobra but that's what she says.
I'm posting in here cause no one post in the SVT section and I trust you guys more.
Woodward_Dreams
12
Farminton Hills, MI
Dec 17, 2009
  • Dec 17, 2009
Does the noise change when you put your foot on the clutch?
hotrodredneck
200
Newport News Va
Dec 17, 2009
  • Dec 17, 2009
find out if it goes away when she presses on the clutch, if so then almost for sure its the TO bearing. But I tell ya, if you have to replace it, you might as well replace the clutch, pressure plate and all while you are at it.
stangfanatic
107
Martinez, Ga
Dec 18, 2009
  • Dec 18, 2009
How many miles does it have on the clock? I had a 96 GT, my cousin has a 96 Cobra and a friend had a 97 Cobra, granted they are older vehicles, but all three of them seized up the TO bearing around 90K miles. They also started about the same also, a little whining noise that would be noticable when you first released the clutch, then over time, it whined constantly unless the clutch pedal was in, then finally the bearing froze up. I agree with hotrodredneck, replace it all if you are going to take the time to disassemble.
7upstang91
936
124
74
Florida
Dec 18, 2009
  • Dec 18, 2009
About 75,000. Okay I will when she gets home tonight.
7upstang91
936
124
74
Florida
Dec 19, 2009
  • Dec 19, 2009
Yes she say's the noise dies down when she pushes in the clutch and changes gears.
stangfanatic
107
Martinez, Ga
Dec 23, 2009
  • Dec 23, 2009
Sounds like it's pretty far along if it just 'dies down a little' when the clutch pedal is pressed. I'd get it in to fix it right away (or do it yourself) before your mom is stranded on the side of the road b/c of a TO bearing... I know the feeling, mine did that to me, it pretty much melted to the input shaft on my 96 GT.
7upstang91
936
124
74
Florida
Dec 23, 2009
  • Dec 23, 2009
Oh crap. Yeah I drove it for myself the other day, pretty bad if I must say so myself. I've never heard one go bad but by reading for over a year and a half on here I figured it out.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
