Throwout Bearing
  • Thread starter Thread starter slow5.0gt
  • Start date Start date Dec 10, 2007
slow5.0gt
138
  • Dec 10, 2007
After finally fixing the car and taking it for a test drive, 9 months since its been out, ive noticed that there is a whirring sound when im driving but disappears when the clutch is pressed in.
IIRC typical symptom of a throwout bearing is when the clutch pedal is pressed in there is a whirring sound.
I can put very little pressure on the clutch pedal and the noise will disappear should I just preload the clutch pedal a little?
Or will I have adverse effect if I just let this whirring sound continue on and on.
C
canesstangnitro
109
Metairie, LA
Dec 11, 2007
  • Dec 11, 2007
I have the same problem on my car and I just changed my throwout bearing. It is still going on even after I changed it. Most people still think it is the throwout bearing
bullitstang1313
713
Indianapolis / Columbus, Indiana
Dec 11, 2007
  • Dec 11, 2007
The throwout bearing is a very common failure. Many models are made very cheaply and go out only after a very short period of time. Another thing to look at is the throwout bearing retainer on the front of the transmission. If you continually lose throwout bearings the bearing retainer may have been damaged.
slow5.0gt
138
  • Dec 11, 2007
I have yet to change the throwout bearing not many miles on it or the tranny only about 40k (not alot to me).
If i push down on the clutch pedal with my pinky i am able to stop the whirrling/clinking noise. If that happens anyone. I stop pushing once i feel the clutch pedal get suddenly stiffer, and the sound dissappears
baldy1
124
Portsmouth Va
Dec 11, 2007
  • Dec 11, 2007
Either the TOB is bad or the fork or the pivot ball or the the front collar is no good. What you can try is to put more freeplay in your pedal. I had the same problem and I put more freplay in the pedal by adjusting the cable and my noise went awat. I had already replaced all the above once and the noise came back after a while. One more thing stupid question what is IIRC mean. I have seen it alot. Just curious.
slow5.0gt
138
  • Dec 11, 2007
freeplay? you mean loosen the clutch cable?
IIRC- If I Remember Correctly
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
