throwout bearing?
  • Thread starter Thread starter twin_turbo_mk3
  • Start date Start date May 10, 2009
T
twin_turbo_mk3
31
  • May 10, 2009
hi so i got an engine 302 and t5 tranny with bellhousing and clutch fork.
i recently purchase a clutch disk with pp and flywheel and pilot bearing.
now my quesion is what else do i need?
i looking at a throwout bearing on ebay now but was curious is there a clip that holds the throwout bearing to the clutch?
my old supra had a clip on the throut bearing but that was because the throut bearing was getting "pull" away from the motor but with the 302/t5 the throwout is getting "push" towards the motor correct?
is there anything else i need to purchase? and if it needs a clip where can i find them?
thanks
Brian992V
880
Lexington,KY
May 10, 2009
  • May 10, 2009
The throwout bearing is held to the clutch fork by a metal bracket. The bracket should be on the clutch fork that you have.
HISSIN50
34
129
May 10, 2009
  • May 10, 2009
What else do you need for what? What are you doing? If a swap, you'll need stuff like a block plate.
T
twin_turbo_mk3
31
  • May 11, 2009
well i thought the throwout bearing is held by a clip so it wont slip off the clutch.
but i guess its different for stangs.
and i have the engine/tranny plate.
and i was wondering what the braket is on the fork is for lol
thanks
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
