90mustangGT said:I had very good luck with them. Yes, they are good, but are they worth the price? That is the question.
Basically, the thumpers will run you about $600. I would really suggest a spring upgrade, that puts you to about &700. You will have to return your stockers, which the shipping might be similar to the core, so go ahead and add the core fee.
Thumper heads are completly rebuild, new seals, 5 angle valve job, and ported well. Consider what a machine shop would charge to rebuild your heads, then consdier the porting. For what Mike (Thumper460) does, the price is very good, but are E7's worth it? Yes and No.
Pros of Thumpers is that they are going to fit exactly like the one's you took off, since they are the same, only reworked, but not changed. A set of alumimum heads will cost you twice as much, and don't forget things like rocker arms, pushrods, gaskets, and even valve covers which you know the stockers will work with thumpers, but chances are, your going to have to buy those things for the Aftermarket heads. Iron heads are more durable, the Thumpers will be as reliable as the stockers, which are rare to have problems. Alumimum is softer, but lighter, and dissapates heat better. Another thing is that with my experience with thumpers, I saw similar if not more performance down below 3000, but a good gain above 4000. The aftermarket alumimums will be lighter, and generally perform better, especially upper RPM.
Flavadave4 said:I definatly noticed a hard pull from 3000 up, good to hear you talkign about them. i am not downing them in any way, I just havent been to the trrack to see if my car is actually faster or not.
giddyup306 said:a friend of mine got a set of E7TEs up to 220 CFM on the intake side!
How did he do that?That takes serious porting skill.
Do those thumper heads come with a flow sheet?
Flavadave4 said:I put a set on my car a month ago along with a Tmoss lower and TFS1 cam, To be honest my car doesent feel to much faster, but i have NOT had a chance to get to the track and fine tune it. Nonetheless you get a fresh sset of heads with some port work, new valves and whatnot.
What are you looking to do with your car?
8950HO said:giddyup306 said:a friend of mine got a set of E7TEs up to 220 CFM on the intake side!
The guy that did my porting has been messing with flow benches since he was 16. He has his own flow bench at his house. He does a baseline, then does very MINOR cutting and looks for a change in flow. He also measures the area and uses some engine simulation software. It also helps that he has dynoed over 500 small blocks. And he's only 25.
FWIW he got my Edel heads up to 260. At 2 hp/cfm that is an 80 hp gain!
Do you dare to post his name and email address? He may get swamped with requests and threaten to do you bodily harm...giddyup306 said:a friend of mine got a set of E7TEs up to 220 CFM on the intake side!
How did he do that? That takes serious porting skill.
