Thumping Drivetrain Problem
  • Thread starter Thread starter The Humungus
  • Start date Start date Jun 28, 2008
T
The Humungus
  • Jun 28, 2008
Hello, I'm new to this forum and to Mustang ownership in general. I signed up here because I've been having a problem with my recently built '89 Mustang and this forum seems to be more active than others. anyway, here's the low-down:
My car has a thumping sound/feeling that feels like it is coming from the driveline or wheels
It is most noticeable at lower speeds, up to about 60mph. I’m not sure if it goes away after that speed or if the thumping just turns into a higher frequency vibration that is much less noticeable.
The thumping is in direct relation to the speed the car is going… so it slows down with deceleration and speeds up with acceleration. It does not happen at idle.
It does not increase when the car is turning and does not get worse under loads or hard acceleration.
The thumping is also present when coasting in neutral, with the clutch disengaged and when rolling with the engine off.
The car shakes when it is driven through the gears on a hoist.
So far… the driveshaft was found to be loosely connected to the rear end (about 6 threads out!!!). This was causing another high speed vibration, but not the lower speed thumping. I’m thinking that the driveshaft may have shaken itself loose due to whatever is causing the thumping …or it could have been two coincidental, but unrelated problems.
The U joints and yoke were replaced and that made the thumping less severe for a day, but then the problem came back after that.
Any help would be greatly appreciated.
HISSIN50
34
129
Jun 28, 2008
  • Jun 28, 2008
Check to see if the DS index marks are aligned.
It's curious that the problem abated immediately after the DS work was done but then returned. Do you see signs of DS rubbing (on ebrake cables or mufflers)? If I'm not sure, I lay down a guide coat of flat black paint on the DS and then drive around the block. Then look at the DS and see where there was interference.
That's where I'd start for now.
Good luck and welcome to the boards!
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
