TICK, TICK.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
My 86 gt has this tick, it sounds like a bad lifter, and has gotten worse over the period of a week, I really dont know where to start! Also when it does this the car will stumble, and feel like it loads up with gas when your driving down the road, just looses all of its balls, so ill punch it and then it straighens out for a couple seconds and then does it again. The oil press. has been severely erradic for an engine with a high vol. oil pump, its been at like 5-10 psi at idle to 15-20 when I punch it or im cruising, sometimes it goes to 40 where it should be and then it drops like a bad habbit down to 10-15 again, I really dont know whats up with this car, I dont drive it crazy meaning over 5k, and dont race it.
If you guys could help me on this one id be extremely grateful as this is my daily ride.
Thanks Josh
As far as the oil pressure goes, are you using a stock gauge? I have had stock mustang oil pressure gauges that are all over the place even though the engine has good oil pressure. Get a good aftermarket gauge if you don't already have one.
The ticking sounds to me like it's probably a bad lifter, maybe one or more that won't pump up all the way until you rev the motor up.
I'm curious to see what other people suggest, but I'm leaning towards one or more bad lifters.
Jeff
Your not going to believe this, I changed the oil and there wasnt a quart and a half in there. There was a little metal in there but it was to the extent of like a half of a BB ground up, in other words not very much at all. I will prolly change the oil filter in a couple of days to get all the crap out. And as far as the lifter and the stumbling goes, it went bye bye. I started her up and instant 50psi oil press. and 70 cruising. which I think is good.
BTW: it has an autometer oil gauge, so I know its accurate.
In a couple of months I plan to put a 347 stroker in it so then ill see how the rings and everything are, or maybe ill do a compression test this week.
Thanks: jchalfan for the advice.
Josh
