  • 1994 - 1995 Specific Tech
tick
  • Thread starter Thread starter NIN
  • Start date Start date May 4, 2007
NIN
452
moorhead MN
May 4, 2007
  • May 4, 2007
I have a tick that is coming from under the car. Any suggestions what this may be?
1TallMF
955
Montreal
May 4, 2007
  • May 4, 2007
I'm assuming you mean from the engine running, like if you leave it idling and step outside you can hear a tick from the engine? Does it go up consistently with RPM? If thats the case check all your header bolts and make sure none have backed-out. If the tick is really actually coming from under the car, check the flanges at the header/mid-pipe and make sure they are nice and tight. Also make sure the rest of the exhaust isn't hitting the body at any place (but that usually makes more of a rattling sound).
Lastly, has this occurred ever since you did the head swap or just out of the blue? I often hear of improper pushrod length and valvetrain geometry issues associated with TW heads...
NIN
452
moorhead MN
May 6, 2007
  • May 6, 2007
Over the car it seems to be loudest over the driverside valve cover. It seems to echo off of the ground and is the loudest and I can hear is pretty loud on both sides of the car. Could valvetrain noise echo off of the ground like that and not be that loud over the engine? Also, can this noise come out the the exhaust. Sometimes my smog pipe gets loose on my h pipe.
thanks,
tom
earleys94gt
1,223
Ashley, Ohio
May 6, 2007
  • May 6, 2007
Since you said the smog pipe gets loose, it might be an exhaust leak. My $0.02
NIN
452
moorhead MN
May 6, 2007
  • May 6, 2007
I looked under there and everything looks tight but I sound like there is a tick coming from the valve cover. Can I possibly do an adjustment on it without taking the lower intake off? It will take me awhile to get that sealed again.
Thanks,
Tom
droptopford 5 0
427
May 7, 2007
  • May 7, 2007
i know my smog pump makes one hell of a tick, even the new one i put on ticked since day one about 20k ago. i also seem to think that i have valver tick, or at least thats my guess... And thats loud enough that i can hear it echo off buildings i drive by at lower rpms even with my o/r h, just a thought as to what urs might be...btw h/c/i is stock and never been opened up
Unknown engine tick
  • 94 Daily
  • Oct 31, 2025
1994 - 1995 Specific Tech Nov 1, 2025
91AOD5.0LX
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
Engine 2008 stang gt lifter or rocker arm
  • Majestic_3v
  • Aug 17, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Aug 20, 2025
Majestic_3v
Only 1 Clean Valve on head?
  • 67Ranch
  • Apr 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2025
AeroCoupe
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
