  • SN95 4.6L Mustang Tech
Ticking
  • Thread starter Thread starter 313Stang
  • Start date Start date Nov 10, 2005
313Stang
89
Detroit
Nov 10, 2005
  • Nov 10, 2005
Ok so this morning I'm driving to work and upon takeoff my car shuttered a bit, I thought it was the trans slipping or something. When I lifted the hood I hear a ticking noise coming from the passenger side head. It sounds like the valve train. My question(s) is this:
1) If I need valve work how much am I looking at paying?
2) Is this a good time to go ahead and do the PI headswap?
thanx all.. by the way my car is a 96 Gt with 125k on the clock... Thanx again..
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Nov 10, 2005
  • Nov 10, 2005
i would just go ahead and do a PI swap
313Stang
89
Detroit
Nov 10, 2005
  • Nov 10, 2005
Thanx.. I think I'm kinda leaning that way.. I need to have my engine rebuilt anyway because my piston rings are going bad so I guess I'll have all of it done at once.. good thing winter is on the way.. guess my baby will spend most of it in the "hospital".
sgarlic
3,085
Nov 10, 2005
  • Nov 10, 2005
I probably would've checked the oil level first, then if it was low, dumped some in and see if that helps.
trailblazr81
571
Hollister, Cali
Nov 10, 2005
  • Nov 10, 2005
Ticking noise??
Iz bomb!!
I would check the oil level first. What did you do to cause the motor needing rebuilt after only 125K miles. I hoope mine lasts longer than that. I use all synthetic oils.
313Stang
89
Detroit
Nov 10, 2005
  • Nov 10, 2005
My oil was low, which was surprising considering I just changed the oil about a month ago.. But it is burning oil and I was told it seems like I need new piston rings which calls for an engine rebuild. I topped the oil off and drove it but the ticking persist. I'm begining to wonder if the trans is going too because it seems to shudder between shifts (auto). I'm gonna take it to the shop and have them run diagnostics on it so I can find out exactly what's the deal..
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 10, 2005
  • Nov 10, 2005
Perhaps a spark plug getting ready TO F'N BLOW OUT???
sgarlic
3,085
Nov 10, 2005
  • Nov 10, 2005
Check the tranny fluid level too.. does it hesitate when you put it in drive at first? Like it takes a second before you feel it go in to drive? Tell-tale sign of low tranny fluid if so.. good luck man.
trailblazr81
571
Hollister, Cali
Nov 10, 2005
  • Nov 10, 2005
Now in my OLD cars with pushrods... when the oil got low and I could hear ticking from valves, I would use this additive when I filled up the oil to stop the ticking. You can find it at Autozone or Kragen with all the cleaners/fluids. Worked good. Comes in quart bottles. May want to give it a try if your trying to put off repairs for a li'l while.
MaxedGT
304
Surrey BC Canada
Nov 10, 2005
#10
  • Nov 10, 2005
  • #10
Could be spark jumping. Bad wire. Is it a snapping type of sound?
313blkstang
38
#11
  • Nov 10, 2005
  • #11
Ok Update... this is 313Stang, for some reason stangnet wouldn't let me post under my name.. go figure.. but anyway on my way home I decided to change the plugs and wires before taking it to the shop in the morning. I pop the hood and find that one of my wires has popped off of the plug.. I push it back on and PRESTO the ticking is gone.. I can't believe that mechanic looked at my car for 20 minutes and told me it was the heads or the valve train. That jerk was gonna charge me $1500 if it was the heads and all it turned out to be was a loose plug wire.. well I am gonna install the new plugs and wires in the morning and all is back to normal.. Thanx fam all of your suggestions really helped me..:SNSign: :Teh-Win:
C
CENTENNIALSTANG
Houston
Nov 10, 2005
#12
  • Nov 10, 2005
  • #12
Mine has done that im running NGK tr6 plugs with nitrous sometimes they back out at highspeeds have you drove the piss out of your car what octane do you put in it. how old are your plugs
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Lifter tick
  • Creomod
  • Oct 31, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2024
Creomod
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Aod to t5 swap will it live?
  • 87slow.0
  • Nov 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2024
87slow.0
