Tight Clutch/Cable
  • Thread starter Thread starter asecretfile
  • Start date Start date Jun 5, 2007
asecretfile
228
  • Jun 5, 2007
Recently bought a 91 notch the clutch pedal is so tight I feel like Im trying to leg press 700 pounds...Ive never had to put so much force on a clutch pedal to get it to disengage....I mean when I get it pushed down it shifts fine and doesnt grind or anything. Could it just be a clutch cable that isnt sliding like it should or the clutch itself?
Thanks
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Jun 5, 2007
  • Jun 5, 2007
In my and my friends' experience that usually means the cable is frayed and needs to be replaced
Take it off and check it.
Dr. Wu 2000
554
Eastern, Pa.
Jun 5, 2007
  • Jun 5, 2007
..... when you do replace it just go with a Ford OEM stock cable, none of that adjustable stuff...and make sure you get a firewall adjuster and clutch quadrant if you do not already have it, will make it much easier for you to adjust.
HISSIN50
34
129
Jun 5, 2007
  • Jun 5, 2007
Check the alignment of the cable from the quadrant to the firewall. Make sure it isnt like a water skiier way off to the side of a boat.
You can disco the cable and run it through the sheath to see if it feels abrasive or hangs up. That said, I agree that a new cable should do you well. Jrichker and I are amongst the only two folks (apparently) whom like(d) our Ford adjustable cables. Just another possible option.
Good luck.
Mikey1968
232
Kommiefornia
Jun 5, 2007
  • Jun 5, 2007
Me too...I like the stock OEM ford cable and quadrant...just wish they made an adjustable quadrant from something other than plastic. I put in a new cable and quadrant....works pretty good.
Anyway, check the cable's routing. If that isn't it, it could be the aluminum bearing retainer is galling up. I had to install a new T-5 and it came with the newer steel bearing retainer.
Good luck,
Mike
88mouse
630
Mooresville nc
Jun 5, 2007
  • Jun 5, 2007
Everthing said so far sounds good and i would try that first. But i would count out the clutch being bad to. I seen a spec stage 2 feel like that and the next week blowed apart.
5.0 con-vert
No soup for you, Joe Rogan!!!
Jun 7, 2005
244
Boca Raton, FL
Jun 5, 2007
  • Jun 5, 2007
Make sure when you get the OEM Ford cable and FW adjuster, you can pick up a multi-hook UPR or something similar. This will save you from the plastic quadrant. I just had the same problem and the cable was my issue. Hopefully that is yours. Good Luck!
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jun 5, 2007
  • Jun 5, 2007
i bought a nice frpp cable, its adjustable and works perfect never given me any problems.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
