So as my sig states and many posts, i currently have a bama chips custom burnt chip for my car, including the lasts updates on parts. All has been well, except for now i am running into certain things in the tunes. Mostly the fact that in the 91 race and 91 performance (haven't tried street) I now seem to be getting engine rattle. Its weird, i have run these tunes since Aug with no problems, and now these last 3 weeks, I have gotten engine rattle, several times.
I get the rattle in 3rd and 4th, from 2500rpm to 4000ish rpm. Like when rolling into the throttle getting up to speed, if i quick stab it, it will rattle for a split sec and then nothing but normal engine noises. I can drive the same pattern over and over and sometimes it does it and sometimes not, there is no consistence to the matter. I thought maybe bad gas, but now have been through 3 tanks and still doing it (3 separate stations too). However, the engine during this rattle does not skip a beat, nor lose any power.
Do you think its detonation, because it doesn't really sound like it compared to the videos i have watched? Or do i need to listen to music more often and just know that these engines are loud? I have not contact bama yet, as i want to here from you all first.
Thanks
Thanks
and said that i can go into the parameters and simply pull a degree or two from the global spark since it is not saved in the tuner but saved in the tune itself. But i did go and clean my mass air, IAT sensors and checked over all my hoses to make sure i did not have a vacuum leak anywhere,. Plus i check for dtc's, but there where none.
. I plan to call bam a on Mon and tell them to take some timing out of my tunes, even though on my handheld its gives me the option to upload the tune I modified or reload the default tune. That way I won't have to worry.
(with no problems). I am going to order a tune from VMP and go from there and plan to stay away from the bama race for good.
