timing adjuster tools needed??
18mm socket (for original crank bolt)
19mm socket (new crank bolt)
10mm socket (ac compressor bolts)
10mm wrench (sensor bolt)
8mm wrench (sensor bolt)
allen wrench for bolts to adjust timing(I think they are 5mm)
utility knife for removing extra silicone under crank bolt
3/8" drive wrench(longer is better for crank bolt)
You'll also use a the 3/8 drive wrench for the belt tensioner.
That should be it.
